skaybird
Sep 22, 2022Tutor
Nighthawk MR6500 Pro M6 Battery Overheat; Mobile or Homebase or Both
We've had an overheat issue where the NETGEAR MR6500 Pro 6 would shutdown. According to the instruction manual, you are not suppose to run with the battery and use the AC battery supply. Is this co...
RidgeRunner1775
Sep 22, 2022Aspirant
Exact same issue. The device gets extremely hot and becomes unresponsive. Most of the time the screen will blink on and off before any user inputs can register so I am forced to pull the plug, let it cool down and reboot.
Bettery is out, original power brick and cable, and wifi is off.
The device is unusable in this state.
