skaybird
Sep 22, 2022Tutor
Nighthawk MR6500 Pro M6 Battery Overheat; Mobile or Homebase or Both
We've had an overheat issue where the NETGEAR MR6500 Pro 6 would shutdown. According to the instruction manual, you are not suppose to run with the battery and use the AC battery supply. Is this co...
ArodiD
Oct 10, 2022NETGEAR Expert
Hi skaybird and RidgeRunner1775 ,
Can you please provide the below details from Settings>More>Device Information screen on the LCD?
IMEI:
FW Version:
Please also provide the following from the device when you experience the issue.
- Login as admin via the WebUI (http://192.168.1.1). Default password: attadmin
- Open a new tab in the same browser and browse to http://192.168.1.1/model.json
- Copy the contents from the web browser and paste it into notepad or similar.
- Upload the contents to this post.
The MR6500 can be powered ON without a battery. This is the recommended method of operation if you plan to keep it plugged in all the time. Also, please make sure to use the supplied power adapter and cable.
ArodiD
skaybird
Oct 12, 2022Tutor
IMEI:
NTGX65_10.01.47.00
That's it for now. Having difficulty with the upload.
