skaybird's avatar
Sep 22, 2022
Nighthawk MR6500 Pro M6 Battery Overheat; Mobile or Homebase or Both
We've had an overheat issue where the NETGEAR MR6500 Pro 6 would shutdown.  According to the instruction manual, you are not suppose to run with the battery and use the AC battery supply.  Is this co...
