skaybird
Sep 22, 2022Tutor
Nighthawk MR6500 Pro M6 Battery Overheat; Mobile or Homebase or Both
We've had an overheat issue where the NETGEAR MR6500 Pro 6 would shutdown. According to the instruction manual, you are not suppose to run with the battery and use the AC battery supply. Is this co...
Oct 12, 2022Guru - Experienced User
ArodiD RidgeRunner1775 skaybird
I recommend that when that kind info information is needed that you send ArodiD a PM directly so as to keep that information more private. Please avoid posting any MAC/WAN addresses, IMEI numbers and product serial numbers in the forums for security reasons.
ArodiD
Oct 13, 2022NETGEAR Expert
Please PM the details.
