skaybird
Sep 22, 2022Tutor
Nighthawk MR6500 Pro M6 Battery Overheat; Mobile or Homebase or Both
We've had an overheat issue where the NETGEAR MR6500 Pro 6 would shutdown. According to the instruction manual, you are not suppose to run with the battery and use the AC battery supply. Is this co...
JohnPeng
Nov 02, 2022NETGEAR Expert
zbrown8482 wrote:
I am having the exact same issues. I purchased the unit brand new in August 2022 and about 2 weeks into using it the unit would go unresponsive and unable to use the screen when it got hot. Unit is plugged in without the battery in it and using the ethernet cable. Unit will not work until unplugged and has cooled down. Are there any fixes to this issue yet?
Could you please specify in details how you use the device?
1. Are you using ethernet port?
2. How many WiFi clients are connected to the device?
3. How heavy data are used on each client?
4. How long does it take for the lockup to happen?
5. Can you log in to WebUI to check what is the device temperature when the lockup happens?
6. What is the carrier SIM you are using, AT&T or Firstnet?
Thanks
John
zbrown8482
Nov 02, 2022Aspirant
1. I am using the ethernet for a work computer
2. Usually during the day only one cell phone is connected to the wifi but typically isn't in use during that time
3. Unsure about the amount of data that is being used but believe it is heavy data usage. I am not the one home at the time. It is my spouses work computer. Typically the unit won't work until 7:45 am and that is leaving it unplugged and off overnight and it won't connect to any device until it's been reset one or multiple times after the 7:30am mark.
4. It varies on when it locks up sometimes right away and sometimes it lasts 10hrs. I haven't found an exact rhyme or reason yet
5. I have not been able to use WebUi yet because I am not home when it happens.
6. Firstnet
6. Firstnet
