skaybird
Sep 22, 2022Tutor
Nighthawk MR6500 Pro M6 Battery Overheat; Mobile or Homebase or Both
We've had an overheat issue where the NETGEAR MR6500 Pro 6 would shutdown. According to the instruction manual, you are not suppose to run with the battery and use the AC battery supply. Is this co...
zbrown8482
Nov 02, 2022Aspirant
I am having the exact same issues. I purchased the unit brand new in August 2022 and about 2 weeks into using it the unit would go unresponsive and unable to use the screen when it got hot. Unit is plugged in without the battery in it and using the ethernet cable. Unit will not work until unplugged and has cooled down. Are there any fixes to this issue yet?
JohnPeng
Nov 02, 2022NETGEAR Expert
Thanks for reporting the issue on the community. After checking with the internal team, I can confirm that the issue is related to using the device without battery. We have a fix for this already. We are going to submit the release to AT&T get their approval before releasing it.
I will keep you posted on the progress. For now, you can work around the issue by using the battery as Kartoffelkonig9 suggested.
Regards
John
- Kartoffelkonig9Nov 02, 2022TutorJohnPeng
Thank you for the update. Hopefully AT&T will approve the fix sooner rather than later. Even with the battery still in the device, its overheating, it just seems to happen less often. The last two days were actually relatively stable for me, but it just overheated again 3 times in the last two hours.
Is it an issue with the device itself or with the firmware? If you can answer or happen to know.- JohnPengNov 03, 2022NETGEAR Expert
Kartoffelkonig9 wrote:
JohnPeng
Is it an issue with the device itself or with the firmware? If you can answer or happen to know.This is FW issue. Device getting hot during data transferring is expected since the chips are getting more powerful and smaller. we have implemented the mitigation algorithm to reduce the performance impact due to heat.
Thanks
John
- Scoe-zNov 04, 2022Tutor
Will you post to let us know when it's available?
I purchased mine 1 week ago and have the same issue. Right now it's at 54c with no battery.
