skaybird
Sep 22, 2022Tutor
Nighthawk MR6500 Pro M6 Battery Overheat; Mobile or Homebase or Both
We've had an overheat issue where the NETGEAR MR6500 Pro 6 would shutdown. According to the instruction manual, you are not suppose to run with the battery and use the AC battery supply. Is this co...
qaidfor
Nov 04, 2022Aspirant
If your router is hot to the touch, it could be a sign that a firmware update is needed. If that doesn't do the trick, you might need to add a cooling element—especially if you're working it hard. Generally, you want router temperature below 90 degrees Fahrenheit.
Scoe-z
Nov 06, 2022Tutor
It's above 100 by just turning it on and not connecting a device. I will try a fan.
