skaybird
Sep 22, 2022Tutor
Nighthawk MR6500 Pro M6 Battery Overheat; Mobile or Homebase or Both
We've had an overheat issue where the NETGEAR MR6500 Pro 6 would shutdown. According to the instruction manual, you are not suppose to run with the battery and use the AC battery supply. Is this co...
qaidfor
Nov 07, 2022Aspirant
could you please log in to WebUI and provide the battery temp and device temp under Diagnose page forpc.onl youtube vanced for pc
Mrspethel
Nov 07, 2022Initiate
30c device and 32c battery with a two server fan wind tunnel. Without the wind tunnel it was 47c-50c and on a warranty replacement device. I’d hoped it was solely a temp issue. Running battery, plugged in, WiFi only (no Ethernet).
- Scoe-zNov 09, 2022TutorIs it working?
- Kartoffelkonig9Nov 09, 2022TutorI’ve been keeping the battery in the device, and while its been “more” (more in quotes because its not that much more) stable, it still seems to overheat and freeze a few times every other day or so. The longest it has worked for me, without freezing, is two days.
- Scoe-zNov 09, 2022TutorI only get a day and a half. I need to make a decision soon this is too much work for the price. Maybe we have a bad batch.
