skaybird
Sep 22, 2022Tutor
Nighthawk MR6500 Pro M6 Battery Overheat; Mobile or Homebase or Both
We've had an overheat issue where the NETGEAR MR6500 Pro 6 would shutdown. According to the instruction manual, you are not suppose to run with the battery and use the AC battery supply. Is this co...
qaidfor
Nov 07, 2022Aspirant
could you please log in to WebUI and provide the battery temp and device temp under Diagnose page forpc.onl youtube vanced for pc
Scoe-z
Nov 08, 2022Tutor
I don't have the battery in, and the device temp sits at 48 - 53 C.
Yesterday I hooked up a pc fan and remove the bottom cover from device then sat the device on the fan. Now it stays at 29 - 33 C. So far it hasn't crashed. I will see how today goes. Oh, and I'm using ethernet.
- JohnPengNov 08, 2022NETGEAR Expert
Thanks for the update. Please keep us updated on your testing.
Thanks
- Scoe-zNov 08, 2022TutorWell it still crashed. So now I have no battery in it, turned off the fan, and with only 3 devices connected via wifi it is at 47c. For the amount of money paid this is a pain. I have 2 days left to take it back and have no internet.
