skaybird
Sep 22, 2022Tutor
Nighthawk MR6500 Pro M6 Battery Overheat; Mobile or Homebase or Both
We've had an overheat issue where the NETGEAR MR6500 Pro 6 would shutdown. According to the instruction manual, you are not suppose to run with the battery and use the AC battery supply. Is this co...
Scoe-z
Nov 08, 2022Tutor
I don't have the battery in, and the device temp sits at 48 - 53 C.
Yesterday I hooked up a pc fan and remove the bottom cover from device then sat the device on the fan. Now it stays at 29 - 33 C. So far it hasn't crashed. I will see how today goes. Oh, and I'm using ethernet.
JohnPeng
Nov 08, 2022NETGEAR Expert
Thanks for the update. Please keep us updated on your testing.
Thanks
