skaybird
Sep 22, 2022Tutor
Nighthawk MR6500 Pro M6 Battery Overheat; Mobile or Homebase or Both
We've had an overheat issue where the NETGEAR MR6500 Pro 6 would shutdown. According to the instruction manual, you are not suppose to run with the battery and use the AC battery supply. Is this co...
georgebanham
Dec 02, 2022Aspirant
Nighthawk M6, MR6110, Battery out plugged into AC home, no wifi for any other devices. just purchased, Supplier/Telco does not answer phone. Help please Thanks
Scoe-z
Dec 03, 2022Tutor
Does it connect to the cellular network?
