skaybird
Sep 22, 2022Tutor
Nighthawk MR6500 Pro M6 Battery Overheat; Mobile or Homebase or Both
We've had an overheat issue where the NETGEAR MR6500 Pro 6 would shutdown. According to the instruction manual, you are not suppose to run with the battery and use the AC battery supply. Is this co...
JohnPeng
Dec 12, 2022NETGEAR Expert
XPLO1T wrote:
Hi John,
What about for Telstra AU users with the MR6500 that are experiencing the same issue? When will the rest of us receive an update? Currently on firmware below which is the latest I can update to..
MR6500-1TLAUS_NTGX65_10.01.38.00_Telstra_01.19Ethernet, wifi disabled, device overheating, screen becoming unresponsive, requires power cycle to turn on again, battery unplugged.
We are working with Telstra to bring in a maintenance release early Q1. These known issues will be addressed in the MR and at the same time, some new enhanced features will be released as well in the MR.
Thanks
XPLO1T
Dec 12, 2022Initiate
Thank you! That's good to know. Shame Telstra is so slow as the device is basically unusable on its current release in this configuration. Lock ups every 2-10hrs, and we are in the middle of Australian summer.
