Oct 30, 2022Guru - Experienced User
Usually its the one that att gives you for setting up hotspots.
Did you check with them?
- hummousOct 30, 2022Guide
I tried nrbroadband but it didn't work.
- JohnPengOct 30, 2022NETGEAR Expert
Please help to capture a model.json file and send PM to me.
- Logon to the webui (http://192.168.1.1 ) as an administrator
- Navigate to URL http://192.168.1.1/model.json via the same browser window
- Capture the results (by selecting all + copy) and send it backPlease also confirm your SIM Plan. Is it from AT&T BYOD plan?
Thanks
John
