AnunC8
Oct 28, 2019Aspirant
Nighthawk, poor signal with antenna
I have a Nighthawk MR1100 Hotspot that I'm trying to get a better connection with. I'm told that antennas can do wonders for them, but I seem to be having no luck. As it stands, the Nighthawk only ...
Blanca_O
Nov 04, 2019NETGEAR Employee Retired
Hi AnunC8
Welcome to NETGEAR Community!
Make sure that network coverage is available in the area. You can do this by checking the ISPs website or using OpenSignal app on your iOS and Android device see https://opensignal.com/networks for more info.
You may also want to try moving the device to a location with a clear view of the sky (for example, near a window).
Blanca
Community Team
