AnunC8
Oct 28, 2019Aspirant
Nighthawk, poor signal with antenna
I have a Nighthawk MR1100 Hotspot that I'm trying to get a better connection with. I'm told that antennas can do wonders for them, but I seem to be having no luck. As it stands, the Nighthawk only ...
W1lliam
Nov 04, 2019Virtuoso
From what you described here, seems your external antenna were plugged onto TS-9 port and the band your M1 landed is not on those bands, you'd better to figure out if that is the case. Some of users tried to verify TS-9 port of the antenna and found they are on low band while another two internal antenna are for high band (B7). So if you are landed on B7, then it might not improve much when trying with TS-9 port of the antenna. Check SETTINGS->DIAGNOSTICS->Current Radio Band to confirm if that is the case.
