AJTheo
Dec 07, 2021Aspirant
Nighthawk R7100LG Disconnects Hourly
I have the R7100LG and have the following issue. ISSUE: The internet connection interrupts for 2 seconds then reconnects *every hour exactly*. As a result I am kicked from online services I have to...
AJTheo
Yeah, no other wifi networks in range of me. Just using the Vodafone SIM.
Checked turning off wifi and just using wired and the problem persits on my PC which is wired directly to the router.
I have tried the SIM in a mobile device both next to the router and at a friends and there was no problem for the full 4 hours I tested it. The router is showing full signal in the connection status window.
I have seen one post that suggests I may be something to do with lease expiry:
but to be honest I don't know enough about this stuff to know if that could be my issue.
AJ
Dec 07, 2021Guru - Experienced User
Ok thanks for checking that.
The test would need to try the actual router at a different location to see if the problem follows the router and not just testing the SIM card at a different location.
Sounds like a possibility and seems like it might be. Lease expires and the router can't or doesn't get or handle a new lease. Could you ask the ISP if they support a static IP address on the SIM/WAN side and if they do, see if you can have a static for a period of time to test to see if the problem continues? Possible if a static IP address assignement on the SIM/WAN side might be helpful.
Over all this may need some NG support review...
