GrochulskiCzes
Sep 21, 2018Aspirant
Nighthawk R7100LG
Hi
I am a happy user of the Nighthawk. I wanted that my cabled net connection would be the main stream of Internet and in case of failur or weak signal the LTE card will be invloved. I installed it...
DarrenM
Sep 27, 2018Sr. NETGEAR Moderator
You may want to check out page 31 on how to fully set this up make sure the settings are correct.
http://www.downloads.netgear.com/files/GDC/R7100LG/R7100LG_UM_EN.pdf
DarrenM
