Grumpy1965
Sep 16, 2022Aspirant
Nighthawk to 4 x 4 antenna
Can I connect a nighthawk to a 4 x 4 antenna using cable splitter? If so, will it affect signal?
Sep 16, 2022Guru - Experienced User
What NG product and model are you referring too?
What kind of cable splitter?
- Grumpy1965Sep 16, 2022AspirantHi its a nighthawk mr1100 and the cable is 1 end 2 female sma other end 1 male sma which I was going to join to the 2 pigtails with ts9 ar 1 end to router
