kenfyoozed
May 14, 2021Aspirant
Nighthawk won't connect to lm1200
I am trying to set up my nighthawk AC1750 to connect to my LM1200. the LM1200 has a straight talk att sim card. I can get the LM1200 to work when connected to my laptop. When I removed the cable from...
kenfyoozed
May 15, 2021Aspirant
Should I run the LM1200 as bridged or router mode?
JohnPeng
May 17, 2021NETGEAR Expert
Run LM1200 in the default Bridge mode is fine. The trick is that after you connect the LM1200 to your router, you need to reboot LM1200 so that LM1200 will get the new IP address from your carrier network and pass the IP to your router.
Please give it a try and let me know if you still see the issue.
Thanks
