58steady
Mar 11, 2021Follower
Nighthawke MR 2100, cant find network security key to connect laptop to modem.
I have been through the manual, been on line without much luck, changed the modem password etc on the computer and the modem automatically changed. But when i log in on the computer i need the networ...
michaelkenward
Mar 12, 2021Guru - Experienced User
58steady wrote:
I have been through the manual, been on line without much luck, changed the modem password etc on the computer and the modem automatically changed. But when i log in on the computer i need the network security key but WHERE is it.?
The "network security key" is usually used to describe the wifi "password".
Look at the label on the bottom or the LCD screen.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
Check the section in the manual LCD Screen.
