TIJ's avatar
TIJ
Follower
Feb 24, 2020
Nighthwak M1
I was told I should buy a Nighthawk M1 to add to my AT&T mobile hot spot in my home so I could add more connections for WiFi.  Will the Nighthawk do that?  Does it just connect to my hotpsot to do that or does it replace my hotspot?
1 Reply
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    What is your AT&T mobile hotspot you are using?
    Thanks
