Jayemcee
Aug 23, 2020Follower
No display showing
I have had my Nethawk for about 5 months and now it is still working perfectly, but when I touch the display pad nothing comes up. I want to be able to access the password (I had recorded it somewher...
michaelkenward
Aug 23, 2020Guru - Experienced User
You have posted your message in the section of this community given over to Nighthawk WiFi Routers. (This is easily done, given Netgear's impenetrable community structure.)
You might get more help, and find earlier questions and answers about your hardware, in the appropriate section for your device. That's probably here:
Mobile Routers, Hotspots & Modems
No need to repost there, unless you want to – that will just clutter up the place with duplicated messages – but you might find advice related to your hardware.
I have asked the Netgear moderator to move your message.
