rabbieb
Mar 24, 2018Guide
No Firmware Support for MR1100 Telstra
Why does the Download site say there is no firmware/software support for the MR1100 Telstra model? The user manual and Telstra both say Netgear provides device support.
I have had multiple problems...
- Apr 17, 2018
Hi All,
We released a new firmware for the Telstra Nighthawk M1 today. This firmware resolves an issue where some users were not seeing data usage on their devices. This firmware also enables Arlo Base Station support and gives user the option to disable Ethernet standby.
https://kb.netgear.com/000055962/Why-can-t-I-see-data-usage-on-my-Telstra-Nighthawk-M1
Kind Regards,
ArodiD
JasonN
Mar 30, 2018NETGEAR Employee Retired
Hi rabbieb,
I just wanted to add to this post just in case other people stumble upon this. Like in the other posts you have replied to, my internal team have been notified and are working on this. They will notify the public when the new firmware is released. Thank you and please be patient. :]
- Jason N
DavePhillips
Apr 04, 2018Aspirant
I am also waiting (not so patiently) for the new firmware. My device was supplied wuth 10.16.04.04 which has the ethernet port going to sleep. This makes the device useless as a 4G backup for a router. I do the Firmware Updae check and it says it is the current firmware version. Can you at least put version 10.25.01.00 back so that I can fix the ethernet port going to sleep?
