rabbieb
Mar 24, 2018Guide
No Firmware Support for MR1100 Telstra
Why does the Download site say there is no firmware/software support for the MR1100 Telstra model? The user manual and Telstra both say Netgear provides device support.
I have had multiple problems...
- Apr 18, 2018
Hi All,
We released a new firmware for the Telstra Nighthawk M1 today. This firmware resolves an issue where some users were not seeing data usage on their devices. This firmware also enables Arlo Base Station support and gives user the option to disable Ethernet standby.
https://kb.netgear.com/000055962/Why-can-t-I-see-data-usage-on-my-Telstra-Nighthawk-M1
Kind Regards,
ArodiD
ArodiD
Apr 18, 2018NETGEAR Expert
Hi All,
Kind Regards,
ArodiD
rabbieb
Apr 19, 2018Guide
Thanks mate, that was easy and the device seems to be working OK.
One thing I did notice - while it's rebooting/scanning you get a screen msg saying it can't find a network and to check your connection. I ignored it.
