rabbieb
Mar 24, 2018Guide
No Firmware Support for MR1100 Telstra
Why does the Download site say there is no firmware/software support for the MR1100 Telstra model? The user manual and Telstra both say Netgear provides device support.
I have had multiple problems...
- Apr 17, 2018
Hi All,
We released a new firmware for the Telstra Nighthawk M1 today. This firmware resolves an issue where some users were not seeing data usage on their devices. This firmware also enables Arlo Base Station support and gives user the option to disable Ethernet standby.
https://kb.netgear.com/000055962/Why-can-t-I-see-data-usage-on-my-Telstra-Nighthawk-M1
Kind Regards,
ArodiD
JasonN
Apr 18, 2018NETGEAR Employee Retired
Hi koom,
I wanted to check in with you and see if you were able to follow ArodiD's post on how to update.
Please let me know. :]
I have also included the link for the process to manually update below from ArodiD.
- Jason N
JasonN
Apr 19, 2018NETGEAR Employee Retired
Hi rabbieb,
You're welcome! I'm glad your issue was able to be fixed with this firmware.
Thank you for letting us know about that and I will forward it to my internal team. :]
-Jason N
