Tricia5
May 28, 2020Follower
No Internet connection
My modem was working fine and then I tried to connect a TP-Link range extender. It said to reset the WPS button which I did - now I have no internet. All the other lights are solid green but nothing showing for the internet. Is there a way I can re-connect please. I'm going crazy trying to figure it out. Thanks for any help.
Tricia5 wrote:My modem was working fine and then I tried to connect a TP-Link range extender. It said to reset the WPS button which I did - now I have no internet. All the other lights are solid green but nothing showing for the internet. Is there a way I can re-connect please. I'm going crazy trying to figure it out. Thanks for any help.
You need a router to connect a range extender to. There needs to be something managing dhcp and that'd be a routers function. A range extender doesn't have that capability.
Does your modem (model?) have an integrated router or is it modem only?
