robkayakmobile
Sep 01, 2021Aspirant
No LTE 4G Netgear Nighthawk M1 ATT Prepaid
Purchased through Amazon Netgear seller. With AT&T I am only able to connect with WCDMA (H and H+). I have long discussions with AT&T still no resolution. Using cellmapper.com I located two ded...
robkayakmobile
Yes I feel your pain... I have mine for a month now.
I am total "mobile".... I got this setup so when I am in remote locations that have described themselves as only ATT.. I wanted a fallback as I have Verizon Jetpack, Verizon Phone with 30gb data, T-mobile phone with 30gb data.
And the 100gb prepaid ATT seems like a good deal...
The ATT site states basically upto 5g access..
Yes our device supports all those bands for ATT.
If you know how to Telnet into the device it looks something like this.. which shows you all the bands we have...
AT!BAND=?
Index, Name, GW Band Mask L Band Mask L ext Band Mask
00, All Bands, 0000000004C00000 000020003000285F 0000000000000002
01, WCDMA All, 0000000004C00000 0000000000000000 0000000000000000
02, LTE All, 0000000000000000 000000030000285F 0000000000000002
0000200000000000 - B46
0000000020000000 - B30
0000000010000000 - B29
0000000000002000 - B14
0000000000000800 - B12
0000000000000040 - B7
0000000000000010 - B5
0000000000000008 - B4
0000000000000004 - B3
0000000000000002 - B2
0000000000000001 - B1
0000000000000002 - B66
0000000004000000 - B5 (850)
0000000000800000 - B2 (1900)
0000000000400000 - B1 (2100)
Now again if you Telnet to the device... when you set in Admin...
Cellular --> LTE ALL...
it will show you something like this....
AT!GSTATUS?
!GSTATUS:
Current Time: 566 Mode: ONLINE
System mode: LTE PS state: Not attached
EMM state: Deregistered Attach Needed
RRC state: RRC Idle
IMS reg state: No Srv
PCC:
LTE band: B12
Note the LTE band: B12 and
This showing that we are "blocked" from LTE
ALL bands in the EMM state: will be "Deregistered"
I am in extensive conversations with ATT over the last day or so...
It is clear they are blocking our devices from 4G... with our only access to WCDMA.
ATT sells the same device... I guess locked.
They have briefly mentioned that BYOD (bring your own device)
is not supported.
But they are on the other hand saying to me that they are working on the situation.
With on Amazon plus 4000 reviews... and on Amazon saying 4G LTE good on ATT and T-Mobile...
Well, need I say more.
Yesterday, as an experiment... I went to T-Mobile and got a prepaid 2G data plan SIM for $10 (actually $20 with SIM and activation.. big deal... worth the "test".
I have a Verizon Jetpack, Verizon Phone, and T-Mobile phone.
I go to remote areas, and city areas. I have done extensive research on cell towers etc.
And I understand the limitations getting connectivity.
Well... T-mobile kinda sucks exactly at my "country" location here.
Verizon great.
Sooooo... putting that "test" T-mobile data SIM into the Nighthawk M1
I immediately got LTE... and in the "city" 20 minutes away along the "main" road
I got 40mps down. Same as my T-Mobile phone.
With the Telnet info I showed above.. and my "test" with the T-mobile prepaid...
It is clear to me ATT is blocking access to true LTE and 4G for our devices most likely bought on Amazon and not the ATT Store.
I figure we have two issues here:
1.) Another misleading representation on Amazon .
2.) ATT not accepting our bring your own device (BYOD) and blocking our access to only buy throught their store.
There is no mention on ATT website about BYOD and these hotspots.
There is no (ATT website) verify your IMEI compatibilty for the hotspot.
T-Mobile website you can easily verify your IMEI compatibily... and as demonstrated no problems with our device.
I have a support ticket here on Netgear.. about this situation with pretty much everything I have communicated to ATT (more specific than here).
Support on Netgear is painfully slow.
On ATT. We don't get true LTE.. 4G.
We only get WCDMA (H and H+ and 3G)
The connection we get, WCDMA is late version 3G max 10mps down.
Which was the first "interpretation" of LTE.
By today's standards it is not true LTE .
Old and going to be phased out by ATT next year which means out $300 device will be useless.
After doing much research... The only single solution (dated 2019) I found was to get a new SIM, card ... well I got a new SIM and that didn't work either.
Go over to https://forums.att.com/
post a message Netgear Nighthawk M1 no LTE 4G
it is a little confusing to select where to put the message to post it.. but
basically you will select..
-->Wireless Forum
-->Phones & Devices
-->Other Phones & Devices
this will keep all the attention to the problem in one place.
That way when people have our problem they can chime in and "vote" on how this sucks.
Learn about the situation...
and maybe "vote" to get it resolved by our complaints.
Here is another link from a post I have on ATT...
my other "post" has been marked private because it shows extensive data to the issue.
I can't imagine we are the only people with this problem... there just haven't been enough complaints.
Post back here if you do post on
krverso
Found your post on the ATT forums, liked, and commented.
Hope you get this resolved soon!!
- robkayakmobileSep 01, 2021Aspirant
Thanks brother (or lady)....
No resolve yet... I am in southern Maryland just hunkering down making sure we survive the tail end of Storm Ida.
Annapolis Maryland just had a tornado go through.
Luckily the tail end of the storm isn't hitting us here hard.
I put in a note about your experience... just tossing the SIM at you and sending you down the
road and the resolution...
To my contact at ATT... not the tech support but he will get directly to them.
So if I don't hear back by ATT Store opening tomorrow.. I will be up there
to try your resolution.
Super happy you got it fixed... sure does sound identical to my situation.
Good thing about the internet is we get to help each other and learn
so many things going down the road... even if they are painfull and frustrating.
Best regards and thanks for the update.
Rob the Kayak Fisherman... on the road...
