robkayakmobile
Sep 01, 2021Aspirant
No LTE 4G Netgear Nighthawk M1 ATT Prepaid
Purchased through Amazon Netgear seller. With AT&T I am only able to connect with WCDMA (H and H+). I have long discussions with AT&T still no resolution. Using cellmapper.com I located two ded...
krverso
Found your post on the ATT forums, liked, and commented.
Hope you get this resolved soon!!
robkayakmobile
Thanks brother (or lady)....
No resolve yet... I am in southern Maryland just hunkering down making sure we survive the tail end of Storm Ida.
Annapolis Maryland just had a tornado go through.
Luckily the tail end of the storm isn't hitting us here hard.
I put in a note about your experience... just tossing the SIM at you and sending you down the
road and the resolution...
To my contact at ATT... not the tech support but he will get directly to them.
So if I don't hear back by ATT Store opening tomorrow.. I will be up there
to try your resolution.
Super happy you got it fixed... sure does sound identical to my situation.
Good thing about the internet is we get to help each other and learn
so many things going down the road... even if they are painfull and frustrating.
Best regards and thanks for the update.
Rob the Kayak Fisherman... on the road...
