dnogwat
May 03, 2018Aspirant
No LTE Advanced connection on AC790
So, I have a problem with the netgear ac790. I reach very low download speeds around 30-50 mbit/sec. According to the specifications of this device it supports category 6 LTE, which means download sp...
JasonN
May 08, 2018NETGEAR Employee Retired
Hi dnogwat,
Thank you for posting to the community with your issue. I will be looking into this situation for a resolution.
Which provider model is your AC790?
Is your device up-to-date to the most current firmware?
Have you performed a factory reset?
Please let me know. :]
- Jason N
dnogwat
May 13, 2018Aspirant
So, did you find a resolution?
