euphos
Feb 17, 2017Aspirant
No USB Tethering Icon in Settings
I have one of the newer AT&T/Netgear AC815S rugged hotspots, and recently had a need to use the hotspot with USB tethered connection. However while trying to follow the tutorial online, I notice ...
- Feb 24, 2017
Hi,
ATT sells two different variants (SKUs) of the AC815.
AC815S-1A1NAS is the consumer SKU and has tethering feature available.
AC815ABS-1A1NAS is the enterprise SKU and has tethering feature removed.
Steve
stevesw
Feb 24, 2017NETGEAR Expert
Hi,
Steve
euphos
Feb 28, 2017Aspirant
Thanks for the reply Steve! I was told by AT&T that there were two different models in their system, but they couldn't tell me the difference.
Now for the million dollar question.....How do I as a business account (Enterprise) go about getting the consumer version that allows USB tethering (without purchasing it myself)? I'm trying to setup a "Business Continuation Plan" where if our wired network goes down, I have a cellular backup. I planned to use the AC815 tethered to a WIFI access point/router (Dovado, DD-WRT E4200 or something similar) which have implemented using a cellular hotspot/modem for internet access.
- steveswMar 06, 2017NETGEAR Expert
Hi,
You will need to contact your ATT account person to see if you can order the consumer SKU.
AT&T SKU 6005A is consumer SKU that allows tethering
AT&T SKU 6012A is Enterprise SKU with tethering disabled
If you are looking for a cellular backup option, then you could also look at using one of our LTE modem products (LB1120 or LB2120).
https://www.netgear.com/home/products/mobile-broadband/lte-modems/?cid=wmt_netgear_organic
These offer an ethernet LAN with LTE WAN so can easily connect up with any current router you may have.
The LB2120 has 2 ethernet ports and can be configured to auto-failover to LTE when the cabled backhaul connection goes down.
Note that LB1120 is available today.
The LB2120 can be ordered but will not be available for delivery until April timeframe.
Steve
- euphosMar 07, 2017Aspirant
Thanks for the info Steve! I'll pass the SKU I need to our IT person (who is the account contact for our AT&T phones).
I'll look into the LB LTE Modems. I already have an AT&T / Netgear AC340U USB modem in addition to the AC815 hotspot. I did see you're coming out with a MR1100 LTE Router that looks interesting. But I've looked at the Dovado Pro-AC, Netgear DC112A and a DD-WRT version Linksys E4200. All of those require an additional LTE source (AC815 or AC340U).
Ron
