Anomadeus
Dec 03, 2020Follower
No working password for reset LB1120
Hello, I have a LB1120 modem that has been reset. I have attempted to login to the modem with the suggested "password" password that will not authenticate. I have also used the password on the st...
Blanca_O
Dec 08, 2020NETGEAR Employee Retired
Hi Anomadeus
Welcome to NETGEAR Community!
The default admin login password is the one that is shown on the modem label, and the modem web page URL is http://192.168.5.1. If it is not accepting the admin password then the next step is to factory reset the unit.
How did you reset the modem?
Please remove the SIM card and hold down the reset button until you see a change in the LED.
Blanca
Community Team
