DaveOlson's avatar
DaveOlson
Follower
Mar 15, 2021
No WPS option on mr1100
I am trying to connect my mr1100 to an extender. When going to the att/Netgear device management page no GPS button is available. I have WPS enabled on the device, but no way to connect with the extender.
1 Reply
  • michaelkenward's avatar
    michaelkenward
    Have you been into the manual for instructions? Is there something in there that doesn't work as described?
    Visit the support pages:
    Support | NETGEAR
    Feed in your model number and check the documentation for your hardware.
    Check the section in the manual Use WPS to Connect to the Mobile Router WiFi Network.
    You may have done this already. I can't tell from your message.
    PS I assume that "GPS" (see above) should have been "WPS".
