nurber
Jun 12, 2017Aspirant
Nominal voltage range of LB1110 ?
Hi. I'm installing this device in an RV and would like to power the device with DC directly. The included AC adapter is rated 12V @ 1A. Can this device be wired directly to an automotive DC supply...
nurber
Sorry, correct model is LB1120. Don't see any way to edit original message
- DarrenMJun 14, 2017Sr. NETGEAR Moderator
Hello nurber
We recommend using AC power. No way you can find a converter for this?
DarrenM
- nurberJun 25, 2017Aspirant
DarrenM wrote:Hello nurber
DarrenM
Hi DarrenM. How can you recommend using AC power when the device runs on DC ? My question is about nominal voltage range. The LB1120 is inherently a DC product and as the included AC power supply outputs 12V DC you should be able to provide me a published or non-published "Operating voltage range" of something like 10.5-14.5VDC.
Appreciatvely, Nurber
