nurber
Jun 12, 2017Aspirant
Nominal voltage range of LB1110 ?
Hi. I'm installing this device in an RV and would like to power the device with DC directly. The included AC adapter is rated 12V @ 1A. Can this device be wired directly to an automotive DC supply...
nurber
Sorry, correct model is LB1120. Don't see any way to edit original message
DarrenM
Jun 14, 2017Sr. NETGEAR Moderator
Hello nurber
We recommend using AC power. No way you can find a converter for this?
DarrenM
- nurberJun 25, 2017Aspirant
DarrenM wrote:Hello nurber
DarrenM
Hi DarrenM. How can you recommend using AC power when the device runs on DC ? My question is about nominal voltage range. The LB1120 is inherently a DC product and as the included AC power supply outputs 12V DC you should be able to provide me a published or non-published "Operating voltage range" of something like 10.5-14.5VDC.
Appreciatvely, Nurber
