kg615's avatar
kg615
Not able to access certain certain websites
My router does not allow me to access certain websites like the new PubMed website for example. I've heard that I probably need to reset my DNS. What is a DNS and how do I reset it?
Thank you,
Katherine
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    What client are you using to access the website and how is the client connected to the MR1100, by WiFi or by USB?
    Thanks
    • kg615's avatar
      kg615
      Though I'm not sure what you mean, I have used Chrome and Firefox to connect. I use it connect to WiFi.
