rosila
May 19, 2023Follower
Not LOGIN M6
1 Reply
Well that wasn't really helpful.
If you'd like help, details are key to helping.
the shorter/more vague you are, the less we can help.
There's a support site with access to manuals, firmware, install guides, etc.
Go to https://www.netgear.com/support/
Type in your model number and from there it'll take you to the above.
Its a great resource to start with.To get a hold of support. Click on "MyNetgear" at the top.
Register an account (or login) and then the device.
From there you can start the support process. Keep in mind that its only free for the first 90 days.
