Smiker
Jul 08, 2023Aspirant
Nrtgear m5100
Hello.. I am from Saudi Arabia and I own a Netgear m5100 device. I suffer from the lack of the N41 frequency and we do not benefit from the device. Please help
- Jul 11, 2023
What is the SKU of your device, MR5100-xxxxxx?
Thanks
John
JohnPeng
Jul 11, 2023NETGEAR Expert
Thanks
John
Smiker
Jul 13, 2023Aspirant
This is device information
Device version
MR5100-1Z1MES-04.02.197.00
Modem version
MPSS.HI.2.0.c3.5-00010-
SDX55_CPEALL_PACK-1.403198.4
Device version
Modem version
- schumakuJul 13, 2023Guru - Experienced User
For the records: A Zain Kuwait branded and carrier locked model. As per a post from mid May 2022. Some more complexity seems to exist due to two hardware versions with different memory sizes. Let's see what JohnPeng can add here.
- SmikerJul 13, 2023AspirantYes, it is true that I bought from Kuwait and was surprised that the version supports the N78 -N77 frequencies and does not support the N41 frequency
I bought it at a high cost đ€§
There is no solution to this problem?- W1lliamJul 15, 2023Virtuoso
You need to look into MR5100C-1BNCNS or MR5100-100NAS if you need n41/n77/n78
