DingalThorpe
Oct 19, 2019Aspirant
NTG9X50C_12.06.07.00 firmware for MR1100 changelog?
My MR1100 informed me that a new firmware was available, and I have upgraded to it. The new version is NTG9X50C_12.06.07.00. Can anyone from Netgear Support tell me what has changed in this vers...
- Oct 21, 2019
Change log is located at:
https://kb.netgear.com/000061333/MR1100-Firmware-Version-NTG9x50C-12-06-07-00-00
n3t
Oct 29, 2019Apprentice
I can confirm that NTG9X50C_12.06.07.00 did solve the ugly "cannot charge during usage" problem!
I just came back from a trip where I was able to operate the M1 in a hotel room for 3.5 days of permanent LTE and WiFi usage with an USB Quick Charge power supply connected and the battery inserted. The M1 was able to charge up the battery to 100% while being in use, and kept the battery fully charged the whole time. This has never worked before, it only did now after upgrading to the new firmware NTG9X50C_12.06.07.00.
Now I hope that the newly released NTG9X50C_12.06.08.00 does not include any regressions. With the charging problem fixed, the M1 becomes the best mobile LTE router that I have ever owned and used.
- WoolaorcOct 29, 2019Initiate
Has anyone done the update and also performed the AT commands to add band locking? Wondering if this will erase that and/or add a password to the interface.
Any improvements for UPnP or Port Forwarding? My Xbox and PC still have Strict NAT with UPnP enabled.
- SebastiiiOct 30, 2019Star
On my side, the upgrade didn't remove the band locking added from AT command, hopefully :)
Can't says about UPNP, I didn't use it
- DingalThorpeOct 30, 2019Aspirant
The band selection functions still work fine for me (or at least, they persist -- I haven't tried updating them).
I don't use uPnP. My provider (AFAICT) doesn't ever allow me to open any ports, so there's no use of that for me.
