DingalThorpe
Oct 19, 2019Aspirant
NTG9X50C_12.06.07.00 firmware for MR1100 changelog?
My MR1100 informed me that a new firmware was available, and I have upgraded to it. The new version is NTG9X50C_12.06.07.00. Can anyone from Netgear Support tell me what has changed in this vers...
- Oct 21, 2019
Change log is located at:
https://kb.netgear.com/000061333/MR1100-Firmware-Version-NTG9x50C-12-06-07-00-00
Woolaorc
Oct 29, 2019Initiate
Has anyone done the update and also performed the AT commands to add band locking? Wondering if this will erase that and/or add a password to the interface.
Any improvements for UPnP or Port Forwarding? My Xbox and PC still have Strict NAT with UPnP enabled.
Sebastiii
Oct 30, 2019Star
On my side, the upgrade didn't remove the band locking added from AT command, hopefully :)
Can't says about UPNP, I didn't use it
