davidt100's avatar
davidt100
Follower
Jan 14, 2022
Offloading MR5100
This is a question about the Nighthawk MR5100 (M5) mobile LTE hotspot.
I theoretically have it set up for offloading via wifi, I am using the ethernet port to connect internet to the computer.  How do I know if the unit is offloading?
Also can you set a cellphone hotspot to be the offloading sorce for the wifi?
Thanks!
1 Reply
  • JohnPeng's avatar
    JohnPeng
    NETGEAR Expert
    Thanks!
    The UI will show the device is offloading to which WiFi network.
    You can offload the device to your mobile phone hotspot.
    Thanks
