carver_ua
Mar 27, 2018Aspirant
one of my MR1100 don't work with QXDM and TEMS software
Hi, i has two MR1100 unit, and want use it with QXDM software. one MR1100 has "NETGEAR DM Port" and "NETGEAR DM Port VSP" and all work OK, but second haven't, and don't work with RNP software ...
carver_ua
Mar 29, 2018Aspirant
I solved this problem. all DIAG ports are there.
- JSchnee21Mar 29, 2018Virtuoso
Hi carver_ua,
We'd love to be able to get more in depth diagnostic info from our MR1100. Can you tell us what these softwares do and how we could get more info from the MR1100. Specially we're looking to get cellular diagnostic info about band, CA, and MIMO.
Thanks,
Jonathan
- carver_uaMar 29, 2018Aspirant
QXDM is sufficient. But need enable DIAG port at MR1100.
this can be a problem. As you can see, support didn't answer anything to me.- JasonNApr 02, 2018NETGEAR Employee Retired
Hi carver_ua,
I have not used QXDM or TEMS software before. I'm glad that you have resolved your issue.
Can you please let us know what you did so we can note this for similar future issues?
Thank you. :]
- Jason N
