ioneng
Aug 26, 2019Aspirant
Optus AC800S does not automatically reconnect to mobile network.
I've been using AC800S on Optus wireless as my home internet since January 2019. I get great speed when it's connected, but it has been having problem staying connected ever since I got it. It has mu...
0x263BCD34
Aug 29, 2019Aspirant
Hi,
Have you tried disabling Band 3? I've been reading a bit about these recently, and it seems they're prone to random resets which may be mitigated by disabling B3.
ioneng
Aug 30, 2019Aspirant
Hey thanks for the suggestion. I actually set it up to only use band 40. That way I can get 3xCA on b40. It's fairly quick when it's working. I can get 40mbs even at busiest time around 8pm.
I just had another disconnection. It's a bit different this time. It actually had the disconnected alert showing on the modem and on the web admin. however there was nothing I can click to reconnect. The only thing worked was choosing a different APN and switch back to the default one.
