z1oid's avatar
z1oid
Follower
Jun 29, 2024
Orbi AX4200 NBR750 HELP!
Device is reachable via networkcable and e already reseted it.
The two Channels (2.4/ 5 GHz) are on and also the Guestaccount.
It runs on an SIM-Card with normal mobile-contract.
Probleme: At first only the guest was connectable and the main wasn’t showing and now you can choose both but some devices aren’t connecting to the router. The connected device aren’t that much, 2-4 Phones, 2-4 Gamingstations like PC/ PS5, Amazon Echo, Vacuum and an Alarmsystem.
Why is it that instable and How can i fix it?
1 Reply
  • CrimpOn's avatar
    CrimpOn
    Managing this system with:
    • The Orbi web browser interface? or
    • The Orbi 'app'?
    When a device connects to the system:
    • Does it remain connected and working correctly?
    • If it has been turned off (or moved away), when it returns does it connect again correctly?
    Are there only specific devices which do not connect and function correctly?
