connergw
Jun 27, 2022Tutor
Orbi LBR20 ethernet connection to TP-LINK AC1200 WiFi router?
We have a cabin that is located between two hills in the mountains of Virginia. There is no cell service at the cabin, but there is service about 250' up the side of one hill. Could I use a LBR20 up...
connergw
Jun 27, 2022Tutor
Thank you for your reply and you make some very good points that I hadn't thought about.
I planned to buy a premade 300' outdoor cat6 cable with factory ends so that will keep me in the limit but I like the idea of not running cable at all. There are alot of trees on that hill so I wasn't sure if a wireless solution, like the Airbridge, would work without "line of sight". I will look at the specs.
I hadn't thought of a heat issue, but will add an small DC fan to the enclosure design.
I'll also look at the LM1200 since wifi at the top of the hill isn't necessary.
Thanks again for letting me bounce these ideas. I needed a "sanity check" LOL
Jun 28, 2022Guru - Experienced User
The airbridge is a bit sensitive to line of sight but if you get it up high enough, you might be fine. If you decide on that route, you can always make sure to buy from somewhere with a generous return policy so if the connection isn't good enough, you can go back to the running a cable option. Plus the problem with airbridge is it adds another burden to the solar plan.
