connergw
Jun 27, 2022Tutor
Orbi LBR20 ethernet connection to TP-LINK AC1200 WiFi router?
We have a cabin that is located between two hills in the mountains of Virginia. There is no cell service at the cabin, but there is service about 250' up the side of one hill. Could I use a LBR20 up...
Jun 28, 2022Guru - Experienced User
The airbridge is a bit sensitive to line of sight but if you get it up high enough, you might be fine. If you decide on that route, you can always make sure to buy from somewhere with a generous return policy so if the connection isn't good enough, you can go back to the running a cable option. Plus the problem with airbridge is it adds another burden to the solar plan.
