Nexus0391
May 09, 2024Tutor
Orbi NBR750 5G router
I have the NBR750 5G Orbi router and I cannot for the life of me get it to update the firmware even though the support site shows a newer version available. On my router, it's showing the last 2 numbe...
- Jun 06, 2024
Sorry for the late update, took me a minute to get to these troubleshooting steps. It looks like it finally worked! I may not have been extracting before, I made sure to extract this time and the firmware is now updated. Thank you for the support!
May 09, 2024Guru - Experienced User
what error does it give you when you try the update?
- Nexus0391May 10, 2024TutorIt just tells me that the update failed to please check my file and that's it. Even tried deleting the downloaded file and re-downloading with the same result
- Nexus0391May 10, 2024TutorAlso here's a snapshot of my firmware update page and the firmware version at the top so that's why I say it looks still out of date since the support site shows a version ending in .66
- plemansMay 10, 2024Guru - Experienced User
A couple things.
1. are you making sure you extract the download prior to uploading it to the router?
2. maybe try going to the .63 or .64 version.
- Nexus0391Jun 06, 2024Tutor
