Marco2073
May 03, 2026Follower
ORBI NBR750 5gh cannot be disabled
I have an ORBI NBR750. I need to force the router to use only the 2.4 GHz antennas by disabling the 5 GHz ones. Even though I’ve done this, I still see some connected devices listed as connected to t...
May 03, 2026Guru - Experienced User
You can't disable 5ghz on the Orbi's.
Why do you think you need to disable it?
What firmware version are you on?
