hbgk
Sep 20, 2023Follower
ORBI NBR750 Rouer 5G
Hi all.
I hope that you can assist me.
We have purchased a ORBI NBR750 router with 5G card installed which we are to use as our primary internet connection. How ever we have a Ubiquity Dream Machine Pro router where all our equipment is attached to and we only need the ORBI NBR650 to supply internet connection and nothing else. In standard settings that works well, but the ORBI NBR750 sends it internal adresse 192.168.1.1 til the Ubiquity router and we need it to send its WAN address which we have paid to get static, so it will not change, but we simply can not find a way to do this in the router settings.
So to simplyfi the case -. We want the ORBI to send WAN adresse to our main router and nothing else.?
Is that possible in any way to have itn do just that?
Or is there any other solutions that we can install to have the WAN IP from the ISP send to the Dream Machine Router?
Thanks in advance
1 Reply
Does this router have wireless access point (AP) mode?
The manual for the NBR750 has all sorts of complicated mode settings that you could try.
Visit the support pages:
Support | NETGEAR
Feed in your model number and check the documentation for your hardware.
