sunilm1992's avatar
sunilm1992
Orbi NBR750 with RBS850 on different firmware versions
Hi everyone, I would be grateful for your advice here.
I have an Orbi NBR750 which I want to use with LTE failover mode and use it with RBS850 satellites (this seems to be a compatible configuration as per the chart here:
https://kb.netgear.com/000065169/Which-Orbi-routers-and-satellites-are-compatible
My RBS850 satellites are running the latest firmware 7.2.6.31 and my NBR750 is running 4.6.5.11_1.5.66 which is the latest version as well.
Is this a compatible configuration of running V7 satellites with a V4 router? Would I need to downgrade the RBS850 satellites to the last V4 available firmware and if I do that will I lose a significant amount of functionality/system reliability? Any reason why Netgear doesn't update the NBR750 to V7?
Thanks for your help!
  • FURRYe38's avatar
    No. v7 RBS FW is NOT compatible with the NBR v4. Please downgrade the RBS to v4 FW.
    • CrimpOn's avatar
      CrimpOn
      A silly question: Do you also have an RBR850 router (perhaps that originally came with the satellites)?
      • sunilm1992's avatar
        sunilm1992
        I have it but I was hoping to be able to use the NBR750 with the satellites I have because I wanted to use the failover functionality in my 5G router 😞
        Do you think that there is a significant disadvantage to using the firmware V4 rather than V7?
        Will netgear update the NBR750 to V7 like they have done for the RBR750/RBS750?
        Thanks!
