TomGee
Aug 26, 2021Follower
Orbi rbr50 no internet
I have recently switched from cable to VDSL.
Previously, I used the cable modem connected to my ORBI RBR50.
With the new VDSL modem (TPLINK AC1200), the ORBI is telling me that there is no internet connection and is magenta.
I am completely at a loss.
Thanks.
1 Reply
You're cascading routers. it causes a double nat.
What is Double NAT? | Answer | NETGEAR Support
How to fix issues with Double NAT | Answer | NETGEAR Support
Also, you posted in the mobile router forum and not the Orbi forum. I'd recommend the proper forum next time.
